HELP How do I get my MAC
How do I get my MAC code. I've search the portal but it only tell you about migrating in.
Any pointers.
Click "Help" at the top of any page and click contact us. Then raise a new query. The mac request is an option from there.
hope you have the same luck i did, a mac in a few hours! who'd have guessed!
"Finally, please enter the date that you want to migrate out on" ?
How do I know the date I will be migrating out? If I haven't got my MAC code I can't sign up to a new provider so I can't tell when I will migrate.
Any help on the above. I need to get this sorted before I go to work in half an hour.
Thanks.
Edit:
Well I've sent it now, whether I have done it right only time will tell!
Ben_Brown
This option is for people who want to migrate out on a particular date, which must be at least 7 days into the future. If you want to migrate as soon as possible, you don't need to choose a date.
Well it doesn't tell you that.
Anyway I've done it now, only time will tell if I've done it right :roll:
I just put asap, because it tells you they keep your account open for 30days after your request, which gives you plenty of time to find a new isp, signup and complete migration before plusnet kill your account.
Got my MAC I'm off to www.metronet.co.uk Cool
There's a coincidence - just requested my MAC, and that's where I will be going too. Smiley
Edit:
MAC key received in 43 minutes - is this a record? :lol:
