HELP 127kbps on max
winnipeg1823
HELP 127kbps on max
Recently been moved from LLU to BTMAX
After 10days I was sync at 1600 with speed tests of 950 to 1100, which I was happy with.
Today my sync has droped to 1200, but every speed test shows 127kbps.
I have raised a ticket but with a response time of at least 18hours I thought I would ask if there is a known problem which makes it go that low
I am plugged into the main socket, all filters Ok etc
Using a lynksys wg54gs, so cannot get noise ratios etc
winnipeg1823
HELP 127kbps on max
just done another test results below. Other speed test sites also show 127. strange there is no difference
14-09-2006 18:57:27 127.9
14-09-2006 17:57:20 127
13-09-2006 17:49:29 483.8
13-09-2006 17:49:07 481.6
12-09-2006 17:34:20 973.7
12-09-2006 17:34:00 962
10-09-2006 13:08:35 883
07-09-2006 18:26:48 951.3
03-09-2006 17:21:10 967.3
03-09-2006 17:20:51 962
25-08-2006 18:04:36 1123.6
25-08-2006 18:03:54 1174.2
winnipeg1823
HELP 127kbps on max
still on same speeds, anyone else with same problem?Huh
Liam
HELP 127kbps on max
What do you get here? www.speedtest.bbmax.co.uk
winnipeg1823
HELP 127kbps on max
down 127
up 335
HELP 127kbps on max
It looks like you must have dropped sync and resyncd at a lower speed.. with problems starting around the 13th..
Have you checked to make sure your extension wiring is top notch? In cases like this, I have often found it to be a few weeks before BT put your speed back up (and not always the 3 days quoted) Sad
Liam
HELP 127kbps on max
So that we can investigate this for you, could you run our automated Broadband Fault Checker at http://faults.plus.net ?
winnipeg1823
HELP 127kbps on max
I will try again, but when I tried before it would not load after the first page.
Wiring is OK as far as I know, currently plugged into main socket
HELP 127kbps on max
this is odd because i'm LLU'd and i've been getting similar speeds even though i am synced at 4mb. Check out the latency on these too:
Pinging www.theregister.com [72.3.246.59] with 32 bytes of data:
Reply from 72.3.246.59: bytes=32 time=155ms TTL=46
Reply from 72.3.246.59: bytes=32 time=346ms TTL=46
Reply from 72.3.246.59: bytes=32 time=170ms TTL=46
Reply from 72.3.246.59: bytes=32 time=189ms TTL=46
It took about 30-40 seconds just to open this page so i could write this message!!!
winnipeg1823
HELP 127kbps on max
Tried the fault checker, again nothing loads after the "initial checks" page
HELP 127kbps on max
Can you run this test and note specifically at the end what the "IP Profile" rate is?
winnipeg1823
HELP 127kbps on max
gotdsl. results were
IP profile 152k
160kpbs up
448kbps down
actual throughput 160kbps
Slangster
HELP 127kbps on max
After following loads of these type of conversations, I thought I should comment on my own experience.
I have the same exact problem as you, even down to the IP profile of 152K! How can this be a fault with BT, modems, routers, cabling, etc. and yet be happening to various Plus Net customers. I have BT coming to check my line this afternoon (as advised by Plus Net) but feel the problem lies with Plus Net, who have not responded to my outstanding call ID: 20251923. Is this problem occuring for other ISP's?
winnipeg1823
HELP 127kbps on max
demster; would be interested to know what BT say when they visit today, if you would be so kind as to post the response, it could be helpful for us in this position.
HELP 127kbps on max
I have exactly the same problem: IP profile 152. It happened two days ago and I went down to syncing at 160. But after this mornings reboot I am syncing at 3744/448 although my speed will be around 130.
I am expecting a BT engineer will be sent by PN next week so on Monday I have to reorganise my house so I plug the router directly into the master socket. This must be done.
I have only had BB two months and they put me straight onto MAX.
BT may have imposed 152 to stop the hundreds of errored seconds I was getting and the disconnections became quite frequent after PN's woes a week last Tuesday. But I am told the return of my sync may sort things eventually.
