Going elsewhere.....can I keep my webspace
I shall be shortly be leaving PN
Can I keep my web address....just as a forwarding address if necessary?
Can I downgrade to a PAYG dialup account to do this?
Or is there any other way?
1 REPLY
I doubt they would let you keep it if you left, but if you down grade it will cost you £14.99 to do so, and £14.99 PM to keep 250mb of web space.
The isp you move to should have some space for you to use there, or get a dedicated host and domain name for much less Here is one, on the startup+ nearly double the size and x amount more bandwidth per month than what you get here.
