Giganews web site
paulgul
Giganews web site
Just wondering if anyone else has problems loading the Giganews web site at http://www.giganews.com/. I'm trying to check my account status
Giganews web site
Yup, same here. Page wont load.
Simon_M
Giganews web site
Yep. Huge pings & tracert times out within their system. Page did load eventually.
C:\>ping www.giganews.com
Pinging www.giganews.com [216.196.100.135] with 32 bytes of data:
Reply from 216.196.100.135: bytes=32 time=2720ms TTL=112
Request timed out.
Reply from 216.196.100.135: bytes=32 time=2610ms TTL=112
Reply from 216.196.100.135: bytes=32 time=2738ms TTL=113
Ping statistics for 216.196.100.135:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 2610ms, Maximum = 2738ms, Average = 2689ms
C:\>tracert www.giganews.com
Tracing route to www.giganews.com [216.196.100.135]
over a maximum of 30 hops:
1 2 ms <1 ms 2 ms [Router]
2 37 ms 52 ms 27 ms lo0-plusnet.pte-ag1.plus.net
3 30 ms 29 ms 60 ms ge0-0-0-403.pte-gw1.plus.net
4 23 ms 21 ms 21 ms ge2-2.fr1.lon.llnw.net
5 92 ms 92 ms 94 ms tge7-2.fr3.lga.llnw.net
6 97 ms 97 ms 97 ms tge2-4.fr3.iad.llnw.net
7 212 ms 256 ms 252 ms giganews.ge3-4.fr3.iad.llnw.net
8 214 ms 243 ms 215 ms g3-0.bb1.dca.giganews.com
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * ^C
C:\>
plusnetsux
Giganews web site
the website www.giganews.com is classed as usenet in the plusnet traffic management system, hence your poor speed/ping. i get the same issue on easynews.com
Simon_M
Giganews web site
www.giganews.com shouldn't be subject to management, although news.giganews.com may well be.
Because Giganews allows connections on port 80 (normal web port) for downloading, a crude management by IP address might be in operation on news.giganews.com, but normally the management software would also be looking at the traffic type flowing, so web pages shouldn't be affected.
Sites like Giganews & Easynews are putting as much effort into bypassing traffic management as ISPs are putting into applying it, so maybe ISPs are starting to hit Usenet sites with fairly broad spectrum blocking tactics.
Giganews web site
Before I changed to PAYG from Premier earlier this week easynews.com was always very slow to load and I think I'm right in saying it was managed as nntp. On PAYG it's as fast as any site to load which suggests that for Premier accounts sites like Easynews and Giganews are still managed as nntp.
Zathras
Giganews web site
Traffic to binary news providers is picked up as usenet traffic regardless of what type of protocol it is, whether it's NNTP, HTTP or ping or something else simply because most binary news services allow downloads over different protocols and different ports.
So on Premier that will mean the traffic is in silver, Plus in bronze and PAYG in gold.
Giganews web site
Usenet speeds on Premier... Nice... 3.83KB/sec avaerage...
http://www.plus.net/support/displayImage.php?strImageFile=KPIPremier_Usenet-headers.rrd.png
Grimbo
Giganews web site
http://portal.plus.net/central/forums/viewtopic.php?t=52717&highlight=
I'm getting anywhere between 2KB/s and 5KB/s this morning (compared with a typical 300-600)
Giganews web site
Unfortunately that is not the case. I've noticed the same with Easynews and have posted about this in the past.
PlusNet, for some unknown reason treat the entire web site on HTTP as they do NTTP server. So it's at a lower priority. Often so low the entire site home page won't even load .. as I have found as well.
Oh well it's not like they're short of capacity - they just need more sessions :roll:
No idea why HTTP Usenet is restricted, where HTTP downloads elsewhere are not, so you are more than capable of making the larger downloads there within the product usage allowance.
I'd still like know of a justifiable reason for this ridiculous policy.
I can actually Remote Desktop onto my work PC, download something there and copy it across over the VPN. This probably uses slightly more bandwidth than it would if I could download it off PlusNet directly.
Maybe it's just me, but I can't see any logic in having things set up the way they are - makes no sense at all.
Giganews web site
I would regularly do this when PN had "DNS problems".
Perhaps all customers should have to sign up for a third party VPN service? Of course, within weeks PN would probably throttle VPN to death...
