Get PhpMyAdmin Running
Could someone possibly send me a copy of their config file with thier "PASSWORDS TAKEN OUT!" but left with the word password in them as I've been trying to delete stuff and it won't let me e.g
MySQL said:
Access denied for user: 'eddland@' to database 'eddland_pn'
so I'm a little confused someone please help + I still wanna get php-nuke up! Smiley
RE: Get PhpMyAdmin Running
I'll send you mine - It does work fine, obviously the only limitation being that the Drop table functionaility doesn't work due to the security problem with the current version of MySQL.
With Regards,
Ian Wild
PlusNet Customer Support
Yea that's what I meant the drop function seems not to work.....
That is by 'design'! The MySQL Admin feature on our portal will let you drop any tables you need to. We are waiting on an update to the MySQL version to negate this problem but until then tables can ONLY be dropped using the portal interface. Everything else in PHPMyAdmin should work fine.
With Regards,
Ian Wild
