Gateway
Gateway
A couple of months ago I had a link that told you what gateway you were connected to.
I have since reformated my computer and forgot to back that link up, does anyone have it?.
Cheers
Adam
Gateway
ipconfig /all
shows your gateway. or do you mean the gateway of Plusnet?
channel
Gateway
If you want to see which PlusNet gateway you are on, you can use this link:
http://usertools.plus.net/@gateway
Gateway
cheers Smiley
