From Broadband to Dialup
Hello,
How can I downgrade from BB to dialup? I would like to keep my account opened... while I move to a different address and check my other options...
Javier
Just cancel your broadband and request that your account is changed to a dialup PAYGO account (which should be the default action anyway but best to make it clear when you cancel).
Plusnet Staff
Plusnet Staff
Or if you want to switch to a subscription dial-up you can also request that as well so if you are going to be using the Internet a lot on dial-up you aren't paying for the phone calls.
Thank you!!
