Folders
Folders
I have tried to create new folders but up to now have failed to do so. I have found the beta mail much more user friendly than the normal system and have not had the problems which seem to be commonplace on this forum.
Tweak it and keep in place please.
Roger
1 REPLY
Folders
Folders are only supported with the IMAP server type. So if you were trying to create folders with POP3 it will not work. This is explained on the main login page under IMAP or POP3
So what interface and server type were you using?
