Firewall with ICS
Firewall with ICS
I have got two PCs linked together using a cross-over cat 5 cable and 2 network cards, both have got Windows XP and Im using ICS, the one which connects to the web(via ADSL) has got Norton Firewall installed on it, my question is:
is the other PC(the one without a firewall) safe?
Cheers
Steve
RE: Firewall with ICS
I seem to recall this question was posed a while ago with the answer that the firewall on the machine connected to the internet protects them all.
Mind you I found it a real pain when the firwall kept asking questions - stopping process dead - and I'm in a different room, Ho Humm!
Norman
> Hi,
> Cheers
> Steve
Hi Steve,
You should be protected when using your Norton Firewall, however I would advise that you consult the Norton documentation that came with your Norton product.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
