Finally....Proper Usenet Speeds
Today I was downloading from an external usenet server and bearly getting 25kbps. Tonight the internet went off and back on and now i am getting 250kpbs. After waiting for 2 months it has for the moment returned to normal. is this just a fluke and will it go back to 25kbps tomorrow?Huh
1 REPLY
kitz
Depends how much you download.
I take it you are aware of the 15GB peaktime cap on usenet?
The 1st 15GB should be fine and you should get high speeds.
Speeds over and above the 15GB limit should still be fine during the offpeak hours.
