Fairly Sucky Speeds
Fairly Sucky Speeds
Over the past few days I have noticed my speeds deteriorating fairly dramatically.
I used to have a pretty stable connection and downloading from Http at 550Kbps but having just run the speed tests at both http://speedtester.bt.com and www.thinkbroadband.com here are the results.
Speedtester:
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 3000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 6176 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 866 kbps
Thinkbroadband.com (formerly adslguide.org)
http://www.thinkbroadband.com/speedtest/results/id/1167955124559831879.html
Both are VERY poor for an 8Mb service......
And before the question is asked....I am only on level 1 management until midnight (which was about 8 min ago anyway!)
