FTP
FTP
Is it possible to give ftp access to another person only to a sub directory off my site i.e. htdocs\domainname\
Lee
RE: FTP
Regards,
Mike
Dear Customer,
Unfortunately this isn't possible. You can however restrict FTP traffic by username by using an .htaccess file.
Regards,
Mike
| Mike Grice....................Unmetered & ADSL solutions
| Customer Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: FTP
> Regards,
> Mike
> Dear Customer,
> Regards,
> Mike
How would that work?
and would that still gove them FTP access to my whole web space and not just the bit I want them to be able to use?
Lee
RE: FTP
It means that it will prompt for a password when the user types in the URL, this will be needed to access any content in that directory.
No, it would just restrict web access to that directory. There's currently no way to implement the solution you require, I'm afraid.
Regards,
Mike
RE: FTP
So the only way to do it is to give them my username and password so allowing them full access rather than just full control of the directory they need.
Or do all the leg work myself.
Lee
RE: FTP
Hi again,
You're totally correct, I'm afraid. I'd recommend doing the legwork yourself as giving your password out is a Bad Thing.
Why not get them to sign up for a Lite / Connect Lite and use MyReferrals? Wink
Regards,
Mike
RE: FTP
If they signed up for a free account would it be possible to give them permission to the directory?
I know I can't do that from my end but maybe you could?
Lee
RE: FTP
Everything at this end is UNIX-based so the permissions are too restrictive to allow such a plan, unfortunately.
Regards,
Mike
RE: FTP
Ok thanks for your help.
Guess I'm stuck doing the legwork
Lee
RE: FTP
No problems,
Let us know if we can be of help.
Regards,
Mike
