FTP program for the File Vault
A suggestion for the PlusNet staff.
Transmit is a very good Mac OS X, FTP program.
I believe that you should put it in the File Vault section of the portal.
http://www.panic.com/transmit/
RE: FTP program for the File Vault
Oops! Sorry.
There are versions of Transmit for 'classic', pre OS X, Mac operating systems as well. (OS 7.5 to OS 9.2.2).
Thanks for your suggestion. I will pass this on for you in the hope that it will be included in the file vault.
Regards
| Dean Wood..........................Unmetered & ADSL solutions
| Customer Support Agent..............for Home & Business
| PlusNet Technologies Ltd..........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
