FTP problems?
FTP problems?
Is there a problem with the ftp server?
I can connect but can't upload or download - it just sits there doing nothing!
Ben_Brown
FTP problems?
Which server are you using? And which client?
FTP problems?
Hi Ben
Sorry I should have included this with the original query.
Server for the ccgi and the www.
I'm using terrapin.
strathbungo1 has tried three different clients. See his post
Ben_Brown
FTP problems?
This is most odd. I am having trouble connecting to it from home, but two off my colleagues aren't having any problems with it at all.
I'm trying to get to the bottom of this now but I'm not sure if it's a problem with my setup or with the FTP servers.
FTP problems?
...I'm not sure if it's a problem with my setup or with the FTP servers.
It would be a coincidence if it was yours, mine and strathbungo1's setup Ben.
Stranger things have happened though. Wink
Ben_Brown
FTP problems?
Having said that I just reallised that my firewall wasn't set up quite right so I've changed it a bit and it now works in active mode.
Passive mode doesn't seem to work, but it's not recommended by the network guys for connecting to our servers.
FTP problems?
Since switching off passive mode it seems to be a lot more reliable on ccgi.
Thanks Ben and John, will keep and eye on it and see if it stops working again!
Andy
FTP problems?
I'm still getting nowhere fast!
I'll try again tomorrow.
FTP problems?
All seems to be working as normal again. Must have been an evening blip because I didn't change any of my settings.
