FTP and Email
FTP and Email
Hi All,
Hope someone can help me. I can't get email or ftp, but can use my browser, I'm using Netgear DG814, it seems to be running fine, have rebooted it etc, but still not getting email or ftp. Any ideas, please?
Cass
FTP and Email
Are you using a software firewall and have you made any changes to your system (updates etc) since these applications last worked?
Are either application generating any error messages?
FTP and Email
Hi Mark,
No changes at all, received my first lot of emails this morning, tired to respond and getting failed on everything. Yes, I am using a software firewall as well as the router and I've not had any problems until this morning. Also tried to connect to my website via ftp and it's saying it can't be resolved.
I've changed connections, taken things off my computer, even changed the microfilter and still not getting what I need. If it was a router problem, I wouldn't be able to get online. This is totally random.
Cass
FTP and Email
When I say taken things off, I mean perpherials.
FTP and Email
What email client are you using? When you try to send email, does it give an error, with text and a number?
If so, could you copy the error message here?
What firewall and antivirus are you using?
FTP and Email
these are the error messages
The connection to the server has failed. Account: 'mail.plus.net', Server: 'relay.plus.net', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
The connection to the server has failed. Account: 'mail.plus.net', Server: 'mail.plus.net', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
Hope this helps.
Cass
FTP and Email
I've tried with OE, Outlook and Thunderbird.
Ben_Brown
FTP and Email
That looks like a firewall problem, do you have any firewall software?
FTP and Email
Hi Cass,
As Ben has said, it looks like a firewall issue.
Can you tell us which firewall and antivirus software you are using?
Fixes: 57
FTP and Email
Whats the odds that the answer is Symantec :lol:
FTP and Email
I've noticed exactly this problem over the last day or so (Outlook express) and yes I am using Norton Internet security 2005 :lol:
I guess an update has broken something. If I disable Norton everything is fine Evil
Fixes: 57
FTP and Email
I believe if you do a manual update this fixes it.
Certainly if you look on the Symantec site you should find something about it as it was a recent glitch.
___oDiN__
FTP and Email
open up norton internet security
personal firewall
configure
network
add the relay.plus.net and mail.plus.net to the trusted sites zone
make sure your email program is closed first
this will resolve this issue
do they same if it affects any other mail servers too
FTP and Email
Tried the manual update with no joy.
odinsrealm's advice did the trick. Ta very much Cheesy
Just had to add all the other pop3 servers I use as well.
___oDiN__
FTP and Email
good to hear
ive emailed symantec to advise them of the problems this update causes
