FTP Problems
FTP Problems
I have been having trouble connecting to my web space using both ftp.plus.net and ftp-proxy.plus.net. I can't ping ftp.plus.net, but can ping ftp-proxy.plus.net.
ftp from the command line gives "Unknown Error", CuteFTP gives "Can't login. Disconnecting...", Internet Explorer gives "A connection with the server could not be established".
Is there anything wrong, or is there something up at my end?
Iain Craven
RE: FTP Problems
> Iain Craven
Hi Iain,
I've just successfully logged into both servers via an ADSL connection. Are you running any kind of firewall? If so try disabling it temporarily, you can also try setting CuteFTP to use PASV mode.
Kind Regards,
Rob
| Robert Kelly.......................Unmetered & ADSL solutions
| Technical Support..................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
RE: FTP Problems
Sorry,
The firewall software on the server, but had crashed trying to upgrade itself. I still can't use ftp.plus.net, but have got in fine with ftp-proxy.
Thanks for your time,
Iain
> Hi Iain,
> Kind Regards,
> Rob
RE: FTP Problems
Hi Iain,
Please let us know if we can help you any further.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
