FTP Problem?
FTP Problem?
Hi All,
Does anyone know if there is a problem with the ftp servers at the minute? I've been trying to access my website to upload stuff both via IE and CuteFTP but all I get is an error saying that the server actively refused the connection.
I've made no changes to my system since the last time I connected to my site (last week).
Anyone got and ideas?
Mike
holdtight
FTP Problem?
Hi Mike
ive got no problem here using explorer or filezilla to access ftp theres also no service status about any problems at the moment
I know its an obvious one but have you tried a full reboot of your pc and modem / router
Bill.
FTP Problem?
Hi Bill,
Yes, tried all that - no change.
Thanks for the reply anyway.
___oDiN__
FTP Problem?
is it just plusnet servers or any u have problems with?
have u disabled firewall tried with/without pasv mode on
FTP Problem?
If you are connecting to your www webspace, try using ftp2.plus.net.
If that fails, try both passive & active FTP transfer modes.
If to your ccgi webspace try pasive & active but you must be connected to a plusnet IP to connect to your ccgi webspace.
