FTP Problem - is it NTL?
I understand that the widespread FTP is resolved. But I'm still having problems, and this has been problematic since I moved to NTL cable broadband 3 months ago.
Since I moved, I had problems logging into FTP, but it did log in eventually, even though it kept cutting out and I had to log in again after uploading about 3 files at a time.
However, for the past week I have been unable to do anything - neither log into, connect or FTP upload.
Acting on all the advice to date, I have used Dreamweaver UltraDev, CuteFTP and LeechFTP. I have turned my firewall off and on. I have tried with PASV mode turned on and off. I have used ftp.plus.net and ftp-proxy.plus.net. All to no avail.
Note I have 3 other hosting accounts with 3 other ISPs around the globe and don't experience an NTL compatibility problem accessing those accounts.
Anyone else using NTL experiencing ftp access problems?
Anyone got any suggestions?
Please HELP :-(
J
chino
RE: FTP Problem - is it NTL?
i was like you i had a few problem... however once i changed to AceFTP i had no problems...
The speed is not good but it works!!!
cUnDaLl
> Please HELP :-(
> J
Did you get the same error when trying ftp-proxy.plus.net? Also if you have any logs from your FTP client detailing any errors you get please attach them to the Contact Us ticket you have raised.
Kind Regards,
Rob
| Robert Kelly.....................Unmetered & ADSL solutions
| Technical Support...................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
