FTP Connection issues...
Ever since I've been on plus net (not that long) I've not been able to connect to my web server using FTP... I've checked with my server providor and their saying everything is fine on their end.
Any idea whats up or how i can fix it? I'm using the Voyager 205 Router and am on a Premium account.
___oDiN__
is it just your web server or any ftp site?
Plusnet Staff
Plusnet Staff
Whereabouts is the FTP connection failing (e.g. rejecting username and password or downloads/uploads failing). As a test try ftp'ing to your PlusNet webspace (ftp.plus.net) and see if that works or not.
There could be several reasons for it not working, hopefully we can try and pinpoint which it is.
Finding Host www.mydomain.co.uk ...
Connecting to *IP was here*
Connected to *IP was here* in 9.140625 seconds, Waiting for Server Response
Error reading response from server.
Connection closed by remote host.
Host type (1): Automatic detect
Thats the error i get... I'll try connecting to the plus net space in just a few moments.
Yes I can connect to the Plus Net FTP server
Plusnet Staff
Plusnet Staff
I've tried it from here but it was quite slow bringing up the login box.
Can try it via command line?
not entirely sure how to do that
command line ftp
Start->Run-> type cmd, hit enter
ftp
open www.mydomain.co.uk
username (delete won't work)
password (as above)
dir
quit
Jay
I get the reply saying
'connected to www.mydomain.co.uk
Disconnected by remote host'
Sounds like the remote ftp server is borked or you have a firewall blocking the data port. Only other thing I can think of is your IP being blocked by your web space provider, doubt that though.
(FTP service uses 20 & 21 TCP by default.)
Jay
Edit: Try using smartftp and noting the error code and description in the log screen, may help.
When using Smart FTP, the log gives me this...
[00:55:18] SmartFTP v2.0.993.25
[00:55:18] Resolving host name "www.mydomain.co.uk"
[00:55:18] Connecting to ***.***.***.*** Port: 21
[00:55:18] Connected to www.mydomain.co.uk.
[00:55:58] Timeout (40s).
[00:55:58] Active Help: http://www.smartftp.com/support/kb/index.php/58
[00:55:58] Client closed the connection.
I might add that I have been able to connect to the FTP server since having using plus net, but it disconnected me moments later.
What webspace does your domain point to?
If www, try ftp2.plus.net and see if you can connect to your normal webspace.
If ccgi, are you trying to connect from a PlusNet IP? If not, you won't be able to connect to the ccgi server as it only allows connects from PN IPs for security reasons.
its a www. and I actully already tried connecting by ftp.mydomain.co.uk
It didnt work.
Still confused over how i can connect to the Plus Net web space, but not my own even though others can connect to my own web space.
Try this temp account I've setup.
Host: zelos.org.uk
username: ftp35857191-1
password: plusnet
You should get something like below, If you do then I would suggest its a badly behaving ftp server. If you get the same error as before then a firewall rule would be most likely answer.
[19:58:08] Resolving host name "zelos.org.uk"
[19:58:08] Connecting to 82.165.55.131 Port: 21
[19:58:08] Connected to zelos.org.uk.
[19:58:08] 220-Microsoft FTP Service
[19:58:08] 220 NTXPW07
[19:58:08] USER ftp35857191-1
[19:58:08] 331 Password required for ftp35857191-1.
[19:58:08] PASS (hidden)
[19:58:08] 230-FTP Server
[19:58:08] 230 User ftp35857191-1 logged in.
[19:58:08] SYST
[19:58:08] 215 Windows_NT
[19:58:08] FEAT
[19:58:08] 211-FEAT
[19:58:09] SIZE
[19:58:09] MDTM
[19:58:09] 211 END
[19:58:09] PWD
[19:58:09] 257 "/ftp35857191-1" is current directory.
Jay
That test server you set up connected right away (in a matter of seconds).
