FOR SUPORT..Again ***** lag on dial up modem and ISDN AGAIN
mike001
Ok at 3am this morning hardly any lag
At 4pm today ...lag VERY VERY BAD
As you can see by the ping times
Witch I pinged constantly 12-13 time
that the pings very a lot.
The trace rout show that the pings very at different
places...I would take it is a hard ware problem your end Sad
This was on the pay as you go ISDN 64k
O and thanks for sortting out my adsl probs with *%*%ing BT
Cant wait till the 20th Smiley
Pinging 194.159.164.183 with 32 bytes of data:
Reply from 194.159.164.183: bytes=32 time=89ms TTL=246
Reply from 194.159.164.183: bytes=32 time=75ms TTL=246
Reply from 194.159.164.183: bytes=32 time=72ms TTL=246
Ping statistics for 194.159.164.183:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 72ms, Maximum = 89ms, Average = 77ms
Reply from 194.159.164.183: bytes=32 time=61ms TTL=246
Reply from 194.159.164.183: bytes=32 time=331ms TTL=246
Minimum = 61ms, Maximum = 331ms, Average = 134ms
Reply from 194.159.164.183: bytes=32 time=64ms TTL=246
Reply from 194.159.164.183: bytes=32 time=69ms TTL=246
Reply from 194.159.164.183: bytes=32 time=188ms TTL=246
Minimum = 64ms, Maximum = 188ms, Average = 97ms
Reply from 194.159.164.183: bytes=32 time=78ms TTL=246
Reply from 194.159.164.183: bytes=32 time=81ms TTL=246
Reply from 194.159.164.183: bytes=32 time=135ms TTL=246
Reply from 194.159.164.183: bytes=32 time=94ms TTL=246
Minimum = 78ms, Maximum = 135ms, Average = 97ms
Reply from 194.159.164.183: bytes=32 time=109ms TTL=246
Minimum = 72ms, Maximum = 109ms, Average = 84ms
Reply from 194.159.164.183: bytes=32 time=122ms TTL=246
Reply from 194.159.164.183: bytes=32 time=181ms TTL=246
Reply from 194.159.164.183: bytes=32 time=85ms TTL=246
Reply from 194.159.164.183: bytes=32 time=63ms TTL=246
Minimum = 63ms, Maximum = 181ms, Average = 112ms
Reply from 194.159.164.183: bytes=32 time=315ms TTL=246
Request timed out.
Reply from 194.159.164.183: bytes=32 time=163ms TTL=246
Reply from 194.159.164.183: bytes=32 time=66ms TTL=246
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss)
Minimum = 66ms, Maximum = 315ms, Average = 181ms
Reply from 194.159.164.183: bytes=32 time=68ms TTL=246
Reply from 194.159.164.183: bytes=32 time=316ms TTL=246
Reply from 194.159.164.183: bytes=32 time=144ms TTL=246
Reply from 194.159.164.183: bytes=32 time=328ms TTL=246
Minimum = 68ms, Maximum = 328ms, Average = 214ms
Reply from 194.159.164.183: bytes=32 time=71ms TTL=246
Minimum = 71ms, Maximum = 75ms, Average = 73ms
Reply from 194.159.164.183: bytes=32 time=207ms TTL=246
Reply from 194.159.164.183: bytes=32 time=275ms TTL=246
Minimum = 61ms, Maximum = 275ms, Average = 151ms
Reply from 194.159.164.183: bytes=32 time=206ms TTL=246
Reply from 194.159.164.183: bytes=32 time=182ms TTL=246
Reply from 194.159.164.183: bytes=32 time=153ms TTL=246
Minimum = 66ms, Maximum = 206ms, Average = 151ms
Reply from 194.159.164.183: bytes=32 time=338ms TTL=246
Reply from 194.159.164.183: bytes=32 time=119ms TTL=246
Minimum = 69ms, Maximum = 338ms, Average = 150ms
Reply from 194.159.164.183: bytes=32 time=524ms TTL=246
Reply from 194.159.164.183: bytes=32 time=297ms TTL=246
Reply from 194.159.164.183: bytes=32 time=247ms TTL=246
Minimum = 85ms, Maximum = 524ms, Average = 288ms
Reply from 194.159.164.183: bytes=32 time=74ms TTL=246
Reply from 194.159.164.183: bytes=32 time=60ms TTL=246
Reply from 194.159.164.183: bytes=32 time=97ms TTL=246
Minimum = 60ms, Maximum = 97ms, Average = 74ms
Reply from 194.159.164.183: bytes=32 time=432ms TTL=246
Reply from 194.159.164.183: bytes=32 time=391ms TTL=246
Minimum = 68ms, Maximum = 432ms, Average = 291ms
Reply from 194.159.164.183: bytes=32 time=269ms TTL=246
Minimum = 69ms, Maximum = 269ms, Average = 121ms
Reply from 194.159.164.183: bytes=32 time=322ms TTL=246
Reply from 194.159.164.183: bytes=32 time=132ms TTL=246
Minimum = 72ms, Maximum = 322ms, Average = 155ms
Tracing route to mike.games.uk.demon.net [194.159.164.183]
over a maximum of 30 hops:
1 58 ms 59 ms 237 ms 192.168.53.106
2 425 ms 105 ms 59 ms vlan501.rhogan1.core.quay.plus.net [212.159.7.12
3 209 ms 68 ms 68 ms 249.core01.access.plus.net.uk [212.159.15.249]
4 65 ms 68 ms 68 ms bhuna.core.plus.net [212.159.15.253]
5 78 ms 68 ms 68 ms atm.core.telehouse.plus.net [212.159.1.66]
6 71 ms 87 ms 68 ms lon1-10.nildram.net [213.208.106.25]
7 72 ms 77 ms 87 ms lon1-9.nildram.net [195.149.20.130]
8 81 ms 87 ms 77 ms linx-1.router.demon.net [195.66.224.12]
9 90 ms 96 ms 265 ms anchor-service-5-fxp0.router.demon.net [158.152.
0.55]
10 78 ms 87 ms 87 ms mike.games.uk.demon.net [194.159.164.183]
Trace complete.
1 53 ms 59 ms 59 ms 192.168.53.106
2 272 ms 124 ms 96 ms vlan501.rhogan1.core.quay.plus.net [212.159.7.12
3 81 ms 68 ms 59 ms 249.core01.access.plus.net.uk [212.159.15.249]
4 59 ms 246 ms 134 ms bhuna.core.plus.net [212.159.15.253]
5 69 ms 143 ms 77 ms atm.core.telehouse.plus.net [212.159.1.66]
6 59 ms 68 ms 77 ms lon1-10.nildram.net [213.208.106.25]
7 72 ms 77 ms 77 ms lon1-9.nildram.net [195.149.20.130]
8 69 ms 77 ms 77 ms linx-1.router.demon.net [195.66.224.12]
9 72 ms 77 ms 87 ms anchor-service-5-fxp0.router.demon.net [158.152.
0.55]
10 78 ms 96 ms 87 ms mike.games.uk.demon.net [194.159.164.183]
Trace complete.
1 56 ms 68 ms 59 ms 192.168.53.106
2 62 ms 68 ms 59 ms vlan501.rhogan1.core.quay.plus.net [212.159.7.12
3 65 ms 68 ms 59 ms 249.core01.access.plus.net.uk [212.159.15.249]
4 59 ms 68 ms 68 ms bhuna.core.plus.net [212.159.15.253]
5 91 ms 124 ms 268 ms atm.core.telehouse.plus.net [212.159.1.66]
6 75 ms 77 ms 77 ms lon1-10.nildram.net [213.208.106.25]
7 297 ms 77 ms 77 ms lon1-9.nildram.net [195.149.20.130]
8 78 ms 77 ms 87 ms linx-1.router.demon.net [195.66.224.12]
9 525 ms 143 ms 96 ms anchor-service-5-fxp0.router.demon.net [158.152.
0.55]
10 166 ms 96 ms 115 ms mike.games.uk.demon.net [194.159.164.183]
Trace complete.
1 399 ms 105 ms 68 ms 192.168.53.106
2 59 ms 68 ms 62 ms vlan501.rhogan1.core.quay.plus.net [212.159.7.12
3 66 ms 59 ms 59 ms 249.core01.access.plus.net.uk [212.159.15.249]
4 422 ms 68 ms 68 ms bhuna.core.plus.net [212.159.15.253]
5 72 ms 77 ms 77 ms atm.core.telehouse.plus.net [212.159.1.66]
6 397 ms 340 ms 77 ms lon1-10.nildram.net [213.208.106.25]
9 272 ms 96 ms 87 ms anchor-service-5-fxp0.router.demon.net [158.152.
0.55]
10 94 ms * 166 ms mike.games.uk.demon.net [194.159.164.183]
Trace complete.
1 52 ms 59 ms 265 ms 192.168.53.106
2 59 ms 59 ms 68 ms vlan501.rhogan1.core.quay.plus.net [212.159.7.12
3 62 ms 59 ms 68 ms 249.core01.access.plus.net.uk [212.159.15.249]
4 66 ms 68 ms 68 ms bhuna.core.plus.net [212.159.15.253]
5 97 ms 87 ms 77 ms atm.core.telehouse.plus.net [212.159.1.66]
6 250 ms 68 ms 68 ms lon1-10.nildram.net [213.208.106.25]
7 62 ms 77 ms 77 ms lon1-9.nildram.net [195.149.20.130]
9 75 ms 302 ms 77 ms anchor-service-5-fxp0.router.demon.net [158.152.
0.55]
10 72 ms 87 ms 87 ms mike.games.uk.demon.net [194.159.164.183]
Trace complete.
1 51 ms 59 ms 59 ms 192.168.53.106
2 66 ms 59 ms 59 ms vlan501.rhogan1.core.quay.plus.net [212.159.7.12
3 66 ms 68 ms 68 ms 249.core01.access.plus.net.uk [212.159.15.249]
5 97 ms 68 ms 68 ms atm.core.telehouse.plus.net [212.159.1.66]
6 678 ms 143 ms 87 ms lon1-10.nildram.net [213.208.106.25]
7 69 ms 77 ms 77 ms lon1-9.nildram.net [195.149.20.130]
8 163 ms 77 ms 77 ms linx-1.router.demon.net [195.66.224.12]
9 69 ms 87 ms 77 ms anchor-service-5-fxp0.router.demon.net [158.152.
0.55]
10 181 ms 87 ms 96 ms mike.games.uk.demon.net [194.159.164.183]
Trace complete.
1 56 ms 59 ms 59 ms 192.168.53.106
2 59 ms 59 ms 59 ms vlan501.rhogan1.core.quay.plus.net [212.159.7.12
3 134 ms 68 ms 59 ms 249.core01.access.plus.net.uk [212.159.15.249]
4 291 ms 77 ms 68 ms bhuna.core.plus.net [212.159.15.253]
5 350 ms 77 ms 68 ms atm.core.telehouse.plus.net [212.159.1.66]
6 66 ms 77 ms 68 ms lon1-10.nildram.net [213.208.106.25]
8 69 ms 77 ms 68 ms linx-1.router.demon.net [195.66.224.12]
9 72 ms 77 ms 77 ms anchor-service-5-fxp0.router.demon.net [158.152.
0.55]
10 69 ms 87 ms 77 ms mike.games.uk.demon.net [194.159.164.183]
Trace complete.
mike001
RE: FOR SUPORT..Again ***** lag on dial up modem and ISDN A
Just logged on With Force 9 pay as you go 64k ISDN
and getting same lag...not quiet as much but still there
Is the force 9 still the same company as plus net?
With freeserve ....no lag at all
Is this happening with just that server or any address? We're not aware of any service problems that would cause this, however if you raise a ticket on your account we'll be happy to investigate further.
Regards,
Rob
| Robert Kelly...............Unmetered & ADSL solutions
| Technical Support......................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
