FAO Plusnet,help neede
ForeverArsenal
Hi
Got a problem this end.
Had to turn power off to router (netgear dg834)for ten mins then reconnected power,after 30 sec or so router connected to exchange at 3616kbps that was approx 2 hrs ago.
However cannot get connected to plusnet adsl,on dialup at mo.
Router says
time connected 00.00
Authentification nothing (blank)
Getting IP address (blank)
Getting network mask (blank)
It just can't connect to plusnet so is there any thing you can do your to get me connected Huh.
*Nothing has changed at this end* apart from power break for tens mins,have rebooted router many times in the past without trouble connecting to Plusnet before.
I am posting this on dial up,so would appreciate advice asap.
Many thanks.
Have you tried re-entering your login/pass on the router or going through the set-up wizard again in case the power cycle corrupted the settings?
What firmware version are you on?
mcgoo
Try connecting only using the ethernet cable and typing in the router address.http://192.168.0.1 or the like.Check your setting and un able any wep or wap security setting then connect.If it connects then you can re enable your security setting and hopefully you should be connected? providing of course it is your router and not pn?
hitachi
Did you change your portal password as advised a few days ago? If this is the first time since that you have rebooted the router you will have to change that as well.
Plusnet Staff
Plusnet Staff
Just checked our connection logs and can't see any failed connections showing up, there's an active connection from about 8 minutes ago, did you manage to reconnect?
ForeverArsenal
Hi Peter
Thanks for reply.
Got two netgear dg834's one with version 1,other with version 3 software,tend to use version 1 router most of the time.
It has just got connected to plusnet adsl now.
Had the same problem about 9 months back for 3 days with a sar 110 router (routers not the problem)+net again.
Getting very close to moveing to BT retail.
Many thanks Peter.
ForeverArsenal
Hi mcgoo
Sorted now many thanks.
ForeverArsenal
Hi.
Yes did do all that and done it again tonight just in case.
Thanks.
ForeverArsenal
Hi Dave.
Yes did connect approx 15//20 mins back.
Thanks for reply.
