Everything Internet forum-wide
Pendragon
Don't know if anyone else is having this problem but when I open the 'Everything Internet' forum and then open a topic the display goes so wide it will not fit on a 1024*768 page and I have to use the scroll bar to move things into view.
Looks like there may be a problem with the auto resize of the page.
Regards, Colin.
JonathanW
Hmm, I've had a quick look in both FireFox 1.5.0.1 and IE6 and haven't been able to replicate this.
Could I ask which browser you're using when you experience this?
I'm using IE6 and had the same problem, but my screen size is set to 1280x 1024.
It would appear to have been caused by the link I posted in a reply I gave, due to the fact there were no spaces the auto wrap did not work. I have edited the post to remove the link and it now displays in browser fine.
Cheers
Mark
JonathanW
That sounds like a reoccurance of problems that we had before and were apparently fixed by development.
But I know over on PN there's been a bit of talk of one of the IE7 beta builds causing problems with certain pages, which is what I thought the original post might have been experiencing.
Pendragon
Sorry I did not reply been busy over the weekend.
Just to let you know I was using IE6 but it looks like Mark's fix worked because everything is fine now.
Thanks. Regards, Colin.
