Error 619
Error 619
For some reason I just got booted off my plus.net account so now am on my ntl one now when ever I retry to connect I get an error 619 - what ever that means, can anyone help?
Error 619
hi just had a look at error msg's Error 619: The port is disconnected.
Error 619
Providing all your cables are connected properly 619 generally refers to a port error.
Best bet is to uninstall your modem drivers and do a fresh install and set up.
If that doesnt sort it, then it may be worth checking the usb port(s) on your PC.
Error 619
How would I reconnect the port?
The little arrows that are in my task bar keep switching between -
DSL Modem
State: No Signal
DSL Modem
State: Traning
DSL Modem
Tx: 228 Kbps
Rx: 1152 Kbps
Error 619
hang on unplug your phone line and then plug it back in give it ten seconds i no it sounds daft but i think that might work
Error 619
I tried both suggestions but neither worked thanks.
what it does when i try to connect,
Connected to remote computer.
Verifying user name and password...
Failed to connect to remote computer.
Unable to establish a connection.
I have checked both the user name and password both are correct,
also now I have another error,
Error 619
Have you tried rebooting your PC?
Firejack
Error 619
Rebooting your PC. First thing to try if anything goes wrong, particularly with Windows! Always amazing how many times this fixes the problem Cool
Error 619
I have rebooted my PC about 5 times now, as firejack said - it's always the first thing to try.
the strange thing is if I click on connect at the right time it will connect for about 4 seconds then it drops again.
holdtight
Error 619
Try unplugging everything and leaving it for just over 30 minutes before plugging it back in again inc modem and phone line
Error 619
will give that a go cheers - Cheesy
Error 619
Left it all unplugged over night and most of the day - switched it on now and it works - Cheesy
Cheers for the help everyone.
holdtight
Error 619
Good stuff Cheesy
