Email not arriving AGAIN
trigat
Its happening again not received any email since saturday, i've also got customers who use Plus Net who are telling me the same thing, when can we expect a resolution to this problem.
James
Not seeing any other complaints currently, and the mail queues are about the lowest I've seen them in the last few months.
I'll try refreshing your mailbox component to see if this helps at all.
trigat
Thanks i'll see what happens, if this works can you do the same on all the other accounts
James
Of course. It's a one minute job.
trigat
Could you also refresh
pinkus
hambleton02
ollerton
Would this expalin why they have not received emails over the weekend.
James
If it has actually worked, then it is possible.
I've refreshed those other three accounts for you.
trigat
Hi no it didn't work they've just been on the phone complaining
Fixes: 8
They haven't got something running that deletes anything marked as [-SPAM-] (or moves it to a different folder) have they?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
trigat
No i turned that off on the plusnet website because of all the problems it was causing
Fixes: 8
There have been many reports that emails are still coming through marked as spam after the checking has supposedly been turned off - it doesn't always work (ever? mine needed a prod)
When I disabled my Spam setting on the portal, 2 mins later I got an email saying - 'Congratulations - your new mailbox is ready to use'. However, this was for a test account I created in 2005!
trigat
Does anyone know if plusnet block email coming from a domain that has been listed on one of those spam lists or do they just mark it spam?
Plusnet Staff
Plusnet Staff
I've just sent you a test message to your PlusNet address which seems to have arrived fine. Is it the PlusNet address or a domain that's having a problem?
There are 2 levels to the spam checker, the first one uses I think spamhaus to block known spammers and the second is the Despam checker that marks the subject line with [-SPAM-].
trigat
That might explain it then, so if a domain that has been blacklisted by spamhaus is forwarding mail to my plusnet account, then they wouldn't arrive would they?
Plusnet Staff
Plusnet Staff
It shouldn't block based on a domain but on the IP address of the sender, so unless the sender's had their IP blocked that's not going to be the cause. Spamhaus's site is:
http://www.spamhaus.org/
