Email help please.......
What does this error message mean?
Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity. Account: 'mail.plus.net', Server: 'mail.plus.net', Protocol: POP3, Port: 110, Secure(SSL): No, Error Number: 0x800CCC0F
I'm on XP using Outlook Express and haven't changed any of my settings recently.
Any help appreciated as I'm a techno-dork. Cheers.
newinvention
Hi, I'm a bit of techno dork too ... but if I get this message it just means the line's gone down. Maybe just temporary. Keep trying, I would say.
If the line had gone down, surely I wouldn't be able to get on t'internetHuhHuh
Are you on Tiscali LLU? and did you get the message in the last half hour?
No, I'm not on Tiscali and I've been getting the message since this afternoon.
Ah OK. The Tiscali LLU hickuped at 20:05ish and I though that may have been your problem, ah well..
I haven't been able to collect my email now for a few hours, the mail.plus.net server don't appear to be accepting the account of password.
Is this happening to anyone else?
les
dunleyhouse
simlar for me:
The connection to the server has failed. Account: 'MAIL.PLUS.NET', Server: 'MAIL.PLUS.NET', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
It means 'your ISP is plusnet'.
dunleyhouse: that particular error means that plusnet's mail server refused your connection attempt. It's normally solved by trying again later as the likely fault is that the server was overloaded.
