Email Problems
StuWard
Email Problems
My outgoing mail server is still not working
I get this message
the message could not be sent because one of the recipients has been rejected by the server Server response "550 sender verify failed" (Account "mail.plus.net", SMTP server "relay.plus.net", Error number : 0x800ccc79)
Any ideas ?
email problems
Give it time these things do happen ,check your settings in Outlook express Tools Accounts ,etc.Make sure your email address is correct User name and password with tick to remember password,spelling hicups are bad news in here as well,also mail.plus.net & relay.plus.net in the right boxes Close email program ,reopen should work if still doesnt ,give it a short time and try it again ,if set up correctly it may just be a glitch in the system somewhere.
StuWard
Email Problems
Nope
Its still not having it
All settings are correct
Julie
Email Problems
Hi there
You did not mention which e-mail client you were using, however, this link will hopefully help you with your settings
http://portal.plus.net/support/email/email_settings/setup/setting_up_email.shtml
StuWard
Email Problems
I'm using outlook and i have all the settings correct to the best of my knowledge
