Email Notifications on Ticket System?
daveyb
I think (I'm pretty sure) that the ticket system used to email you when there had been an update on your ticket, but it doesn't appearto do that anymore.
Has anyone else noticed this or is it just me?
Thanks, David
Are you sure the email address detailed at the bottom of the question entry page is correct? Have you tried senduing an email to it to check the mailbox is OK? Also you are actually checking the email address listed?
The most recent updates to my tickets, and the new one I raised this morning have all resulted in emails being sent.
daveyb
Hi Peter,
Well the email address submitted with the fault is correct (I've checked) - but I'm not at all sure it was at the bottom of the question entry page though. Having said that, this ticket was raised through the Broadband Fault Checker, although you'd hope that this would work in the same way and send you an email notification when the ticket was updated but maybe it doesn't?
Thanks, David
Automatically created questions/tickets (like the checker does) do not generate an email. The fault checker also creates the tickets in a closed state so there can never be a CS reply to them.
Only user generated questions and when CS reply to such questions produce an email.
daveyb
Thanks for that Peter. We don't have the ideas/suggestions forum anymore do we, so how do we make suggestions?
Seems a shame that the automated tickets doesn't generate a notification email when the ticket gets updated. A Customer Service agent responded to the ticket a couple of days ago but I didn't know until I went in myself last night with the intention of bumping my ticket to find out what was happening!
Thanks, David
PUG are currently in discussions with PN to try and get the suggestions thing going again, but in a diferent format. Details should be announced on the PUG forum shortly.
