E-mail timing out
Fixes: 57
E-mail timing out
Anyone else seeing this problem this morning
Task ***** - Receiving' reported error (0x8004210A) : 'The operation timed out waiting for a response from the receiving (POP) server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'
E-mail timing out
Yep - on and off for the past few days now.
Even when telnetting into it, it sometimes just sits there and does nothing :?
Laugh
E-mail timing out
I've got a problem with webmail too. It was running extremely slow but now it has reported this error:
Mailbox Error
The server responded - 1
Refresh and try again
Check that you are not accessing your mailbox simultaneously in two or more windows. A file-lock is active per session accessing your mailbox.
Check that two sessions of your account are not active - only one user per login is accepted
Try accessing again in a few minutes
If you are having continued problems using Webmail or have encountered a bug, please provide details to our support team using the Help Assistant, including any information provided in the above error message.
Looks like a general mail problem.
bluewhale
E-mail timing out
anyone from plusnet looking into this problem?
perhaps we should be running tests on our routers first to see if it's our problem :roll:
E-mail timing out
IMAP's running fine for me and I've had no problems whatsoever!
EDIT - 12:15 - POP is working fine as well for me!
EDIT 2 - 12:18 - webmail is dead for me
"The server responded - 1"
Laugh
E-mail timing out
Webmail working again now - must have been a blip
E-mail timing out
PlusNet are checking this out right now.
bluewhale
E-mail timing out
shouldn't there be an amber light on the service status?Huh
E-mail timing out
Give them a bit of time to replicate and identify it Smiley
Grimbo
E-mail timing out
Yea - I'm getting it too.
Its just a little sad that anytime I get a problem I have to come to the forums to see whether anyone else has the same problem.
I have been with Plusnet for 8 years but they are seriously trying my patience now.
E-mail timing out
I'm unable to access my email either via Outlook Express or via the Plusnet portal.Just timing out!! Sad Sad
James
E-mail timing out
I've just raised this as a P! (36869).
I'll get a service status out shortly.
Bluewhale, can you please ensure that your encapsulation and virtual circuit settings are correct on your router? That way the email problem affecting ~150,000 people should be resolved.
thehatman
E-mail timing out
Yes, I can't get email via Outlook today.
E-mail timing out
Cheers for picking this up so quickly James!
:lol: Wink
E-mail timing out
Mand Beckett has posted this on the portal.
Customers trying to access email via a mail client (Outlook Express etc) may receive a 'timeout' or 'connection failed' error.
Could I repeat it is not just problems via an email client but also directly via the plusnet portal ?
Denis
