E-mail problems?
E-mail problems?
Is there a problem with the email servers?
The reason I ask is because I have about seven of them and only the first two and the postmaster one, are allowing mail through.
All the others revert to a box that says: please enter your name and password for the following server.
I haven't touched any of my passwords or names. Why should the first two download ok and not the rest?
I get the message and error using Outlook Express, I just get locked out when I try and access them from the webmail.
Thank you.
Plusnet Staff
Plusnet Staff
E-mail problems?
Hi John,
I've not seen any other problems reported and all seems OK for me.
I ran a quick check on your mailboxes and they don't show any problems and log in fine.
Can you try it again and see if it's OK now, I'd suggest re-entering the username and password into Outlook Express in case it's been accidentically overtyped when it failed.
E-mail problems?
Hi Dave
Sorry about the delay getting back to you; I signed off for the night.
I tried my email this morning and everything worked a treat, must have been one of those gremlins that pester us all every once in a while! Smiley
