Dungeon And Dragon Connetion problems.
Attempting to connect to the new D&D online hangs at the connecting to logon server stage. There are a list of ports to be opened ,which have been both on firewall and Router. There is a suggestion on the games forum that continued failure to connect may be due to limitations imposed by the ISP. Please tell me that isn’t the case with Plusnet!!
Ports involved
80
9000-9010
2900-2910
443
5015
Any one else hitting this problem?
JonathanW
None of those ports are blocked on our network, so there shouldn't be anything causing these problems on that part. I'd suggest checking out any official support forum for the game to see if there are any other people suffering from similar issues.
If no one else is having these problems, then I'd suggest raising a ticket through to support.
Thanks for the Info.
It knocks down one of the argumnets put up on the offical game site as a possible answer.
Back to Chasing them again
