Dropped connections/sync problems?
BlueMeany
I have noticed a number of threads on this topic, but before I go delving deeper (theres a lot of reading!!!) I just wondered if anyone could give me a more 'specific' area to look at.
Currently using a Sagem USB Modem.
I seem to lose connection (could be sync) every-so-often. Now I had noticed it was mainly when using P2P, but this morning its done it just browsing. I ran the DSL test that comes with the modem, and the results log is posted below. When I try to connect again, windoze is showing error 721.
The workaround that I use at the moment is just to turn off my 'puter and restart it (windoze xp). It all then works fine again without me touching any settings.
Any ideas where I should be looking first?
---log below---
****************************USB DSL TEST GUI***************************
* DSL GUI Version : 2.02
* Driver Version : 9.E
* Hardware Version : 500B
* Firmware Version : 43E2EAD4
* Operating System: Whistler build: 2600
* Number of Processor : 1
* Processor Architecture : INTEL
* Processor Level : 6
* Processor Model : 25
* Processor Stepping : 60
* Memory Usage : 63%
* Total Physical Memory : 804810752
* Available Physical Memory : 297017344
* Total Virtual Memory : 2147352576
* Available Virtual Memory : 2114547712
* Start Time : Monday, August 15, 2005 10:32
DSL TEST CONFIGURATION
INTERFACE TEST CONFIGURATION :
TEST : ENABLED
MODEM TEST CONFIGURATION :
TEST : ENABLED
EXPECTED DSL MODE : G.DMT
DATA MODE TIMEOUT : 60
VPI : 0
VCI : 38
LINE TEST CONFIGURATION :
TEST : ENABLED
OAM_VPI : 0
OAM_VCI : 38
NUMBER OF CELLS TO SEND : 5
OAM LOOPBACK TYPE : F5E2E
NETWORK TEST CONFIGURATION :
TEST : ENABLED
VPI : 0
VCI : 38
EXPECTED DRIVER TYPE : WAN
EXPECTED ENCAPSULATION : BRIDGE_LLC
DSL TEST RESULTS
1 - INTERFACE TEST RESULTS :
The interface test is passed
2 - MODEM TEST RESULTS :
MODEM test is passed
3 - LINE TEST RESULTS :
TEST IS FAILED : CO modem did not respond to OAM cells from RT modem.
Possible causes :
1 - The set of OAM VPI/VCI does not match with the ones at CO side.
2 - OAM LoopBack type is not the proper type.
Remedies :
1 - Check the VPI/VCI and use the correct values.
2 - Check the OAM LoopBack type and use the proper type.
4 - NETWORK TEST RESULTS :
Network test is passed
CMV CONFIGURATION
1 - DIAG02 : 0
2 - DIAG03 : 0
3 - DIAG22 : 0
4 - DIAG23 : 25
5 - DIAG25 : 21
6 - DIAG47 : 0
7 - DIAG49 : 1D
8 - DIAG51 : 18E0BCB
9 - DIAG52 : 18E0F07
10 - DIAG53 : 0
11 - DIAG54 : 0
12 - INFO10 : 43E2EAD4
13 - INFO08 : 1C
14 - INFO14 : 0
15 - OPTN00 : 8002C444
16 - OPTN02 : 0
17 - OPTN04 : 0
17 - OPTN07 : 0
18 - PSDM01 : 73E77
19 - RATE00 : 470009
20 - STAT00 : 82208210
Have a read through this:
http://usertools.plus.net/tutorials/id/10
BlueMeany
I had looked through that, and was hoping someone might have been able to decipher the Line test error things first:-
Possible causes :
Remedies :
All the abbreviations mean nothing to me, but are the same errors whenever I can't get anything (i'll not say 'lose the connection' because in theory the connection is still active - just can't do owt!) This problem now appears to be occuring more regularly.
Don't have access to other modems etc, but I never had this problem with tiscali broadband (many other problems, but not this one!!)
vic_newey
problem is those stats don't show the bits we want to see, , the noise levels & attenuation etc.
