Drop down menus - not all displayed
The drop down menus don't display fully, only the top half displays and the bottom just seems to fade away.
Otherwise seems quite reasonable.
Mike
1 REPLY
Similar problem
Over all the web based mail prog seems to work well, but the pop down menus dont stay down to be able to select any of the options. They pop back up as soon as they have been selected .Is it just my system? Or is there anything I can do my end.
