Drastic change in Download Speed
Typical speeds upto now have been:
DOWNLOAD: 3000-4000kbps
UPLOAD: 350-400kbps
Since last night however:
And from BT Speedtest:
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 135 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4736 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 116 kbps
What is going onHuh Help please.
James
Your equipment has resynched at a stupidly low level so BT have kind changed your bRAS to 160Kbps.
If you're sync speeds remain the same for the next 2-3 days, your speeds will then return to what they used to be, however this is unfortunately a drawback of BT Max ADSL service.
If it helps at all, exactly the same thing happened to my connection and I fully understand how much of a pain it is.
Thank you for the prompt reply James Smiley
It's like going back to the dark ages, memories of ISDN many many years ago :shock:
I'll leave it a few days, whilst regularly reseting and checking my router.
Thanks again.
