Download speed vs Upload speed
I have noticed that over the past week that when I am uploading files
my download speed reduces significantly
Any ideas
I have 1mb broadband premier
Martin
1 REPLY
You can notice that especially if you're maxing out your upload, Downloading also requires some upload bandwidth and if that is unavailable due to it being used up by other application then your download speed will suffer, by how much is dependent on what you're downloading and what program you're using to do it. Bittorrent for example requires quite 'a lot' of upload speed to be able to download at very high speeds
