Domains
eglwys
Domains
Sorry if this has been answered before or if it is a silly question.
I have a domain name included in my subscription. Do I have web space associated with it, and if so how much and how do I upload to it?
Many thanks in advance
Martin
Domains
You automatically get web space with a Plusnet account irespective of having the incuded domain.
The amount of space you get depends on the type of account you have i.e. home account business etc.
The normal space with a premier account is 250mB spread over all the servers htdpcs, ccgi,and front page.
You can upload to it using any FTP software or if you are using Internet explorer 5 or greater (most people are these days) then you can just type ftp://ftp.plus.net in the address bar of your browser and this will open a window with at least one folder in it called htdocs. Double click on that and you are in your webspace and can drag and drop files into it.
Hope that helps.
eglwys
Domains
Many thanks for the info. I knew about the normal webspace but was hoping that I had a second webspace for my domain name, but alas it seems not.
Thanks again
Martin
Domains
No unfortunately you don't get any more web space by having a domain name Cry
