Domain forwarder
UberMensch
Domain forwarder
I've set up a domain ubermensch.aceshells.com which is supposed to forward to ubermensch.plus.com. Problem is, when I try and go to the PlusNet one, I get the usual cannot find server. I'm currently being throttled because of (3GB) bandwidth usage, which is completely out of order anyway.
Does the throttling affect the webspace too?
1 REPLY
Fixes: 8
Domain forwarder
Are you forwarding to ubermensch.plus.com or www.ubermensch.plus.com?
Unless you asked for your rDNS to be changed ubermensch.plus.com would normally point to your own connection whereas www.ubermensch.plus.com points to your Plusnet webspace.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
