Does a failed broadband fault check auto. start a ticket?
daveyb
My ADSL won't connect reliably at all today so after trying the usual reboots, plug into test socket, etc. I used the portal's broadband fault checker which came back and said the line had failed and that a fault was likely. It concludes with the line "Your support request has been escalated to the correct team for review".
My question is do I need to do anything more to progress this or has this effectively raised a ticket for me automatically to get BT to do whatever they now do to diagnose the fault?
Thanks, David
Hi David.
The automated system and the faults team should take care of it from here on in for you.
daveyb
Thanks Mark.
David.
