Does PN allow blogs on it's webspace?
I have tried to set up a blog, using blogger.com on my webspace and it says access denied. Is access by services like blogger.com disallowed?
gswindale
Worked fine for me just now - at what stage did you get the access denied message?
Have you used your FTP client to change the permissions on your uploaded items to 755 or above?
When I tried to upload the test from blogger.com.
I'll have a fiddle round tomorrow, it's obviously something dumb I'm doing!
Fixes: 8
I'm not sure he's on the correct server:
C:\Documents and Settings\John>nslookup ccgi.andypowel.plus.com 212.159.6.9
Server: ptn-cdns01.plus.net
Address: 212.159.6.9
*** ptn-cdns01.plus.net can't find ccgi.andypowel.plus.com: Non-existent domain
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 8
@andypowel
Are these php scripts you're trying to run?
gswindale
Sounds as if the settings weren't entered correctly. Were you making sure that the files were being copied to either the /htdocs directory or a sub-folder of it (/htdocs/blogger)?
I don't know if they are php scripts to be honest, just running whatever is on blogger.com
I'll try to set the path. I just assumed that when it logged in using my username it would go to the correct default directory.
Well, it required my default directory.
Thanks for all your replies guys.
