Do we have to request MaxDSL?
dunleyhouse
Do we have to request an upgrade to MaxDSL, or will it just happen sometime.
When I check the Broadband availability at BT it says I can only get 512k anyway, which is what I get now. So is there much point in requesting an upgrade?
From reading these forums, it sounds like it doesn't work anyway.
It all depends on you signal to noise ratio. If its not much above 12dB now then there is a chance that you could get slower on MaxDSL.
Plusnet are deliberately not upgrading people that are on 512 because there line must be pretty poor anyway.
If you still feel like trying it than you will need to go to the Help and Support pages and there is an option in there to request it.
dunleyhouse
I'll think I'll leave it then.
