Do we have a date for slow max fix yet ? ?
petsyb
So are we any closer to having a date for when we will be able to connect at the speed the modem has always said (7mb or > for me) rather than half the speed the https://portal.plus.net/my.html?action=stable_rate has said ? (1mb and < for me)
Stable rate 2mb been connecting at over 7 for over 2 weeks !
http://portal.plus.net/central/forums/viewtopic.php?t=43855&highlight=
BT report – still slow and well below 400kbps for 8 MB
http://portal.plus.net/central/forums/viewtopic.php?t=43779
How long till stable rate set on MaxDsl (so slow) ?
http://portal.plus.net/central/forums/viewtopic.php?t=43759
Why Oh Why Oh Why ! 7.3mb but actually 500k
http://portal.plus.net/central/forums/viewtopic.php?t=43592
Plus net stable rate set way to low - please reset !
http://portal.plus.net/central/forums/viewtopic.php?t=43417
8mb upgrade slower than my old 2 mb !
http://portal.plus.net/central/forums/viewtopic.php?t=43175
MAXDSL - Constant Disconnections
http://portal.plus.net/central/forums/viewtopic.php?t=43334
MAXDSL Modem trained 7424kbps actual 318kbps WHY ? ? ?
http://portal.plus.net/central/forums/viewtopic.php?t=43291
petsyb
Bump
And why the hell am I constantly getting disconnected, every few seconds disconnected twice whilst writing this Evil
make that three times now
If you search for a message from dtomlinson, he mentioned somewhere that the changes to BRAS will occur on the 10th this month.
SW.
3Mb FTTC
JonathanW
When your connection drops, is it a sync loss that's causing it or just the connection itself that's dropping it? If you're loosing sync at all then use the faults checker to raise it through to our faults team so that they can look at it for you.
