Discussion Forums slow
JJ
Logging into the member centre is fine usually less then 2 sec.
Going to other places once in the member centre is fine, 2 sec. Again
BUT click on the Discussion Forums and it takes 10-15 seconds before anything happens.
Is this just me ?
Zathras
Nope not just you, definately sluggish
Yup ..sluggish here too, timed out on several occasions.
Firejack
Was lightning fast when they upgraded the Portal at 1pm. Got slower after dinner but I put that down to the usual congestion in the evening on Plus.net. Even considering this its a bit stop start browsing just now.
Ive always found PN's portal to be shockingly slow tbh
ptrichardson,
Historically, it has been but they are doing lots of work to bring loading times down to under two seconds and it seems to be working, the forums are certainly much snappier than they used to be....
craiglay
Pretty damn quick here!!
Craig
Unfortunately that is not the case for everyone by the looks of things. It's very inconsistent for me...sometimes within 2 secs, more often than not its more like 10-15 secs and sometimes its just timing out.
Though it could just be the same as all surfing during peak hours lately...very patchy indeed. The amount of pages timing out or taking an age to load is ridiculous in the last couple of weeks.
James
The amount of work that we've been doing to improve the speeds over the portal is definitely not completed. Listen out for further announcements from Liam in the coming weeks.
Liam
Was it just the forums, or other areas of the Portal? How were other websites? Working fine? Done any speedtests elsewhere?
James
I also get varying speeds on the portal forums.
Mostly slow here too, taking 10 -> 15s for some pages to load.
Accessing the forums for the first time in a new FF tab also takes ages before I see anything.
James
I'm getting anything from 1s-30s. I'm currently on a 35mbps line.
Liam
We're going to get some new servers in the new year that we're going to run some diagnostic tools that will allow us to specifically identify the worst offending pages and scripts for us to focus on and optimise.
It is strange that you're seeing problems, though, as it seems to be working a treat right here.
It's patchy in the forums..but at its worst when trying to navigate from the forums to another part of the portal or vice-versa.
