Discrimination ?
thunderbird30
Discrimination ?
Something has just occured to me when I looked at the useage policy and it's allowances.
I notice that if you are lucky enough to have a 2mb and over connection speed,you will be able to use 30-40gb of data transfer before the dreaded slowdown occurs.
If you are unlucky enough to be stuck on 2mb (or 512 in my case) then 20gb is your lot! Why can't we have a level playing field?
Discrimination ?
The 4mb and 8mb are higher priced and therefore have higher data limits. The higher speeds are currently being trialed, so most of those people will have a maximum of 2MB, same as the rest of us.
Fixes: 5
Discrimination ?
As far as I'm aware you could still upgrade to the upto 4/8Mb packages and take advantage of the higher usage limits, but still have a 512 line.
Phil
