Disconnects.
passer
Disconnects.
My speed is fairly reasonable, averaging around 2 meg, but for several hours now, my connection is up and down like a yo-yo. Seems to drop on or around the half-hour and hour marks, with some difficulty in re-synching at times also. Anyone else experiencing this? Is it perhaps to do with network-balancing automation, either at BTw or PlusNet?
(and that's on top of the wretched DNS problems)
Plusnet Staff
Plusnet Staff
Disconnects.
If it's dropping sync then the cause will be something between your equipment and the exchange. If it's happening regularly on the hour/half hour then it sounds like there's something interfering (Christmas lights or central heating or something that switches on/off at these times?).
A loss of sync won't be caused by something our side and unless there's an MSO at your local exchange I'd say it was anything deliberate BT's side (not could easily be a fault somewhere down the line).
Best to check at the master socket, remove everything from the line and check for anything that could be interfering.
Disconnects.
Same thing here, fluctuating SnR and rapidly incrementing FEC, HEC and CRC errors. I'll go direct the master but it looks the the exchange may be playing up again. It's been fine for about a week or so then gone to rat pooh tonight.
passer
Disconnects.
It's been fine today, so I'm assuming that they were messing around at the exchange. Thank you for responding, Dave T.
