Disconnections.
Disconnections.
Hello,
I got my line upgraded the other week and i was chuffed! however what they dont tell you is that if you go to the toilet or make a cuppa or just turn around for 3 mins, when you turn back you have been disconnected!
can anyone else say they have similar probs so i can raise a ticket.
Disconnections.
Cant say I have expirenced this. Are you using a USB modem? Is there an option for idle disconnect?
Disconnections.
linksview, in addition to checking for an idle timeout (applies to USB and non-usb kit) does your PC go into powersave mode ?
