Disconnect
Disconnect
Just got disconnected aswell.
Also got a netgear router.
Was going to check router settings, but decided on a final reconnect which worked.
Bit odd. Something must be going on.
1 REPLY
Disconnect
Hi there.
Odd indeed. Our radius logs are showing as you having an active connection for the last 41 Days, 22:34:41 (on going).
When you say disconnected, did you lose synch or just data transfer?
P.S Where you meeaning to reply to a specific thread?
