Disconnect and Problems with PlusNet Site
Hi All,
First post, got a couple of problems. Hopefully someone can shed light on at least one.
Problem 1: Numerous disconnects daily for about 3-4 weeks. To my knowledge i have not been unbundled but have been on IPStream Max since 18/04/06 - was absolutely fine until, as i said, 3-4 weeks ago.
My principle PC is connected to a netgear DG834Gv2 router via an ethernet cable. Typical log looks like:
Sat, 2006-09-09 10:59:25 - Router start up
Sat, 2006-09-09 13:46:33 - LCP down.
Sat, 2006-09-09 13:46:35 - Initialize LCP.
Sat, 2006-09-09 13:46:35 - LCP is allowed to come up.
Sat, 2006-09-09 13:47:35 - Initialize LCP.
Sat, 2006-09-09 13:47:35 - LCP is allowed to come up.
Sat, 2006-09-09 13:48:02 - CHAP authentication failed
Sat, 2006-09-09 13:48:02 - LCP down.
Sat, 2006-09-09 13:48:35 - Initialize LCP.
Sat, 2006-09-09 13:48:35 - LCP is allowed to come up.
Sat, 2006-09-09 13:49:35 - Initialize LCP.
Sat, 2006-09-09 13:49:36 - LCP is allowed to come up.
Sat, 2006-09-09 13:49:48 - CHAP authentication success
Sat, 2006-09-09 13:54:19 - Send out NTP request to time-g.netgear.com
Sat, 2006-09-09 15:59:07 - LCP down.
Sat, 2006-09-09 15:59:13 - Initialize LCP.
Sat, 2006-09-09 15:59:14 - LCP is allowed to come up.
Sat, 2006-09-09 16:00:14 - Initialize LCP.
Sat, 2006-09-09 16:00:14 - LCP is allowed to come up.
Sat, 2006-09-09 16:00:40 - LCP down.
Sat, 2006-09-09 16:00:47 - Initialize LCP.
Sat, 2006-09-09 16:00:47 - LCP is allowed to come up.
Sat, 2006-09-09 16:05:48 - LCP is allowed to come up.
Sat, 2006-09-09 16:05:48 - CHAP authentication success
Sat, 2006-09-09 16:16:28 - LCP down.
Sat, 2006-09-09 16:16:34 - Initialize LCP.
Sat, 2006-09-09 16:16:34 - LCP is allowed to come up.
Sat, 2006-09-09 16:22:45 - Initialize LCP.
Sat, 2006-09-09 16:22:45 - LCP is allowed to come up.
Sat, 2006-09-09 16:22:46 - CHAP authentication success
5 Disconnects in 4 hours, not impressed.
Problem 2: I cannot complain because i am also having problems with the plusnet member centre! When i click on "My Questions" and "Connection Settings" the pane with the info does not load.
OS: XP sp2, Browser: IE7 beta 2
Many thanks for those squinting at the log.
By the way, I am moving in 2 months. If the problems are not my fault and they are not resolved i will be moving to another ISP.
Regards,
Paul (uk1807)
edit - cleaned up erroneous log entries
terminal
are those times GMT or BST (you can check by looking at the Schedule page of your router setup, shows current time and look to see if "Adjust for Daylight Savings Time" is ticked)
if they are GMT then 2 of those times (16:16 and 13:46) are the same as the llu disconnects (which you are not on), just coincidence or something more?
It might be useful to keep a record of your disconnects and post them on here
timps
I had the same drops on BT MAX with drop of syncs at
13-52
13-54
13-57
13-59
14-01
other custers of disconnects with loss of sync between
17-12 ... 17-20
18-56 ... 10-04
19=54 ... 20-27
all in all 22 disconnects
another of life's mysteries
timps
The log is GMT.
Anyone got any toughts on the website problem?
Paul
Website problem sorted.
Browser to blame.
