Disconects
Disconects
I get a lot of disconects now. the green arrows go from green to yellow with it saying training .....
Its happaning offten now.
Any ideas why?
1 REPLY
Ben_Brown
Disconects
There's many, many reasons for your connection to be disconnected. From your description it sounds like you are losing the signal from the exchange. Try running through this tutorial and see if that helps.
If none of that helps, try the fault checker in the member centre.
