Difference between PAYG and Premier
ceridwen
There has been a number of posts by CSC recently stating that PAYG gives better performance than Premier. In particular it has been stated a few times that all PAYG traffic is Gold.
However, the produc descriptions at http://www.plus.net/support/broadband/network/traffic_management.shtml state that the same classification of traffic types to gold, silver etc. is used for both Premier and PAYG. i.e. that until you start hitting the Premier threholds you should be getting the same performance as on PAYG!
Which are correct - what CSC are saying on the forums or the advertised product descriptions?
Matthew
Fixes: 8
Broadband PAYG is designed for customers who want to enjoy high-speeds at all times of the day. As such, our PAYG service is prioritised on our network at all times, for all types of traffic.
I've been using Wireshark to monitor my traffic and everything I've seen has been Gold.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ceridwen
However, further down the same page when you select PAYG in the dropdown list you get:
How do we manage traffic on our network?
Different types of traffic have a different priority at peak times on our network, with time-sensitive applications such as gaming and VoIP having the highest priority
with the table listing the different types!
If that statement and classification table is not appropriate for PAYG why does it still display?
Given it does display, PN could change the why PAYG is prioritised and claim it is still within the product description!
Matthew
Firejack
....I've been using Wireshark to monitor my traffic and everything I've seen has been Gold.
How can you tell that looking at the output from wireshark? CS asked me to send them a capture for an FTP transfer. No way of telling what is prioritized as what reading the output.
Fixes: 8
1000 00.. = Differentiated Services Codepoint: Class Selector 4 (0x20) - That's Gold traffic
Plusnet Staff
Plusnet Staff
Most traffic on PAYG is in the gold queue, the exceptions are things like gaming and VoIP which get a higher priority in Titanium.
The table on that page isn't specific to PAYG (that and the "Why do we have to manage traffic on our network?" question appear on all account types) and is there as an overview of the network. As I say, all traffic on PAYG will fit into either Gold or Titanium, while for Premier the traffic will fit into Titanium, Gold and Silver (with Bronze only for peak time level 1/2 management on P2P/Usenet/FTP).
So to be crystal clear, there is never any PAYG traffic classed as Silver?
SW.
3Mb FTTC
Zathras
If that were true Winmx would work peak times like torrents do(more or less).
Fixes: 8
You've missed out the word "supposed". I suspect that this is not the case. Cry
Just tested my PAYG 2Mb MaxDSL line a few minutes ago:
bbmax = 1.4Mb
bt.com = 1.8Mb
SW.
3Mb FTTC
If the only exceptions are that some PAYG traffic is Titanium means that all other traffic must be Gold.
Just seeking confirmation.
SW.
3Mb FTTC
Zathras
Whats does that show?
You mean my speed tests?
It shows PN is the limitation in speeds on my connection. Sombody might call this lack of capacity, the customers, some might call it being profitable, the suppliers.
SW.
3Mb FTTC
Zathras
Ah gotcha now Cheesy. Yes it doesnt matter how good your line is if its 'managed' to the degree we see ,its as bad as a poor line.
Plusnet Staff
Plusnet Staff
Nope, no PAYG traffic in silver and none in bronze. It's all either gold or titanium, in the future some may go in platinum when it starts being used.
