Deployment of Additional capacity
James
Feel free to discuss the recent announcment made here.
YAY - Goes to download loads of stuff :lol:
bobbygeorge
so frustrating,
would be nice to see the benefits but I can only ever connect to 'ptn-ag2' no matter how many re-connects.
:roll:
James
I'd expect the network to be back in balance in a couple of days so the additional capacity will be shared amongst everyone then.
paulgul
A couple of weeks ago I switched from premier to PAYG because of speed issues on usenet. Do I have to wait a specified time before being able to go back to premier assuming speed issues will now be improving
Paul
James
You can only change product once a month.
paulgul
Is that a billing month? because the change was made before my last billing date (22nd)
James
Ok, to clarify Smiley
You can only change product once every 30 days.
paulgul
Thanks James, thats clearer. At least by then there should be some feedback one way or the other on speed issues.
Paul
Plusnet Staff
Plusnet Staff
so frustrating,
:roll:
Weird, RADIUS shows you've connected on all 5 gateways in the last 48 hours. How are you checking which gateway you are on?
WoooooHooooooooooooooooo
Kakkoii
P2P speeds have improved. I got up to 45 KB/s download! Cheesy
Plusnet Staff
Plusnet Staff
Good to hear it's having an improvement. The new segment isn't in balance with the rest of the pipes yet, probably going to take a few more days to get it balanced right, only just under 1,000 customer on the new segment, average on the others is just over 2,000.
James I raised a MAC request and got a code as a result of this. But as it is now fixed I don't think i'll be using the code. If I do nothing will I stay with plusnet? or will my account be cancelled?
James
Hi Matt,
As long as you don't use the MAC Code that you have requested, then your account will remain active. We don't prematurely terminate accounts on the basis that a MAC Code has been requested.
