Default Email
Default Email
Please could you tell me if it is possible to change my default email and if so how do I go about it
Thanks Coley
1 REPLY
RE: Default Email
Hi Coley,
Your default e-mail address is anything@username.plus.com so it does not matter what you put before the @ sign.
The username.plus.com part of the address cannot be changed unfortunately as the username is used to define your account.
Regards
Josh
| Josh Berry.......................Unmetered & ADSL solutions
| Technical Support.......................for Home & Business
| PlusNet Technologies Ltd.............@http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
